Get the best gaming audio anywhere. As a smaller and lighter headset that delivers detailed audio with far superior noise isolation, Sound BlasterX P5 is the perfect headphone for gamers who want to enjoy gaming not only at their desk, but also on the go.
Built with premium materials, two professionally-tuned, high sensitivity 7mm FullSpectrum drivers deliver true soundstage with rapid response, rich cues and responsive bass; giving gamers a tactical advantage through the ability to perceive details, depth and location with pinpoint accuracy in real time.
Ultra lightweight yet extremely powerful
Weighing at only 12 grams, the Sound BlasterX P5 is a tiny marvel that fits 7mm Neodymium magnets which deliver amazingly high sensitivity 114dB audio with brilliant clarity. The drivers are also specially tuned to deliver a true soundstage with rapid response, giving gamers a tactical advantage through the ability to perceive details, depth and location accurately as they happen. -
Titanium coated drivers for faster response
The Sound BlasterX P5's drivers feature a thin coating of titanium - which has the highest strength-to-weight ratio of any metal. This means that while the diaphragm is stiff and strong enough to resonate clear, high-fidelity audio throughout the audio spectrum, yet it is light and precise enough to ensure ultra-fast response times and accurate sound reproduction. -
Port tube array for optimized bass
Sound BlasterX P5 features a port tube array that allows the headphone to punch above its weight when it comes to bass reproduction for headphones of this size. The array modifies the bass response properties of the earphone housing and increases low frequency response. -
Spiral-ribbed ear tips for advanced noise isolation
A well-balanced audio signature promises an excellent soundstage for hours of gaming without listening fatigue, and swappable soft, spiral-ribbed ear tips that come in three sizes ensure a perfect fit for an improved isolation. The spiral-ribbed design is designed to work very much like an exoskeleton that keeps the ear tip pushed out snugly against the inside of the ear canal. -
High-performance inline microphone
Traditional inline microphones do the job for phone calls, but often lack the clarity required for gaming communications. The inline, omni-directional electret condenser microphone on the Sound BlasterX P5 is designed to deliver the vocal quality of the full sized boom microphones used in gaming headset. Communicate clearly with your team mates - no more mis-comms.
- Creative Sound BlasterX P5 - earphones with mic
- Product Type
- Earphones - wired - 3.5 mm jack
- Recommended Use
- Game console, portable electronics, computer
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 10 - 23000 Hz - Sensitivity 114 dB/mW
- Impedance
- 16 Ohm
- Diaphragm Type
- Titanium
- Microphone Technology
- Electret condenser
- Controls
- Microphone on/mute switch, answer/end
- 1-year warranty
- Product Type
- 12 g
- Recommended Use
Audio Output
- In-ear
- Wired
- Sound Output Mode
- Stereo
- 10 - 23000 Hz
- Sensitivity
- 114 dB/mW
- Impedance
- 16 Ohm
- Diaphragm
- Titanium - 7 mm
- Magnet Material
- Neodymium
Microphone
- Sensitivity
- -42 dB
- Impedance
- 2.2 kOhm
- Audio Input Details
- Omni-directional
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Carrying case, audio splitter, 3 pairs of silicone ear tips (small, medium, large)
- Cable Details
- Headphones cable , Audio splitter
- Limited warranty - 1 year
