Creative Sound Blaster Roar 2 - White
Quicklinx: C3TVWS00 Mfr#: 51MF8190AA002
The Sound Blaster Roar 2 is specially designed for people who not only appreciate portable speakers for their audio performance, but also for their looks. Wrapped in a stylish sleek housing, the Sound Blaster Roar 2 exudes understated sophistication of a well-designed audio instrument that continues to impress - whether it's in the office, at home or a party.
  • Dual orientation
    Whether it's horizontally or vertically placed, the Sound Blaster Roar 2 tunes to your acoustic preference. A horizontal placement lets you experience room-filling and balanced audio. Alternatively, a vertical placement has a smaller footprint but it produces louder and more directed audio and brings the controls on the back panel closer to you. The Sound Blaster Roar 2 is meant to have dual orientation, with your convenience in mind.
  • Bi-amplified design
    Most portable speakers utilize a single amplifier to reproduce the entire audio spectrum. With a single amplifier design, much demand goes into reproducing the lows and mids, which compromises the delivery of the highs. On the other hand, the Sound Blaster Roar 2 utilizes two amplifiers - one dedicated to driving lows and mids, and another is solely dedicated to deliver the high frequencies. This allows the speaker to produce uncompromisingly clear, high definition, and well-balanced music. The top-firing bass and mid-level driver is also laid horizontally, reducing the speaker's center of gravity, thus stabilizing it.
  • Same five high-performance speaker drivers
    Despite having a smaller enclosure, the Sound Blaster Roar 2 houses the same premium five drivers as the Sound Blaster Roar. From the two far-field tweeters, a powerful subwoofer and two unobstructed passive radiators, which are beautifully machine-finished, every element of the design is thoughtfully considered to enhance your audio experience.
  • Clean, powerful bass
    The active 2.5? driver pumps out impressive mids and lows. Directing the audio upwards also stabilizes the speaker and provides for a wider soundstage that does not require the listener to be situated in the audio sweet spot.
  • Compact, powerful, high frequency drivers
    Durable and lightweight high-frequency drivers deliver balanced highs. These dual 1.5" premium drivers are also designed to provide far-field high-frequency dispersion.
Creative Sound Blaster Roar 2 - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Digital recorder
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Audio Formats
WAV, WMA, AAC, MP3, apt-X
Speaker Details
Speaker - stereo x 2 - active , Speaker - subwoofer - active
White
Built-in Decoders
SBC decoder, aptX
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
18.8 cm x 10.9 cm x 5.1 cm
1 kg
Digital recorder
Flash memory card
Hands-Free Function
Enclosure Colour
White
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Built-in Decoders
SBC decoder, aptX
Audio Formats
Controls
Power on/off, volume, call answer
Interface Type
USB
Additional Features
Bi-amplified
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x tweeter driver - 1.5" , Speaker: subwoofer driver - 2.5" , Speaker: 2 x Passive Radiator - side-firing
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A) , USB
Power adapter, micro-USB cable
Power Source
USB, battery
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
6000 mAh
Run Time (Up To)
8 hour(s)
18.8 cm
10.9 cm
5.1 cm
1 kg
