The Sound Blaster E5 is a 24-bit/192 kHz high resolution USB DAC and portable headphone amplifier. Built with precision audiophile components, a best-in-class 600 ohm headphone amplifier and aptX technology for Bluetooth, the Sound Blaster E5 is the perfect audio component for music lovers, whether they are on the move or beside their PC/Mac.
Compact External USB DAC for PC/MAC
The Sound Blaster E5 is the result of Sound Blaster's relentless audio innovation since the PC era, backed by decades of legendary audio engineering expertise. With a proven track record of providing high-fidelity PC audio for discerning ears, the E5 now brings a high-resolution audio experience for your use with laptops, smart phones and tablets. -
Designed for the audiophile in you
The Sound Blaster E5 is designed from the ground up, to reproduce high-fidelity audio with minimum distortion and noise. It is built on the flagship Cirrus Logic CS4398 Digital-Analog Converter (DAC), with an impressively high 120dB signal-to-noise ratio (SNR) that supports sample rates of up to 24-bit/192 kHz resolution. -
High-resolution audio playback
Sound Blaster E5 is able to decode audio files ranging from MP3s and CDs (16-bit/44 kHz) to high-resolution 24-bit/192 kHz files, be it from your PC/Mac or other smart devices. -
Hi-Fi companion for your mobile devices
You can play digital audio direct from your iOS or Android device via the Sound Blaster E5 to your headphones. Digital audio signals are sent from the device directly to the Sound Blaster E5, which decodes them without any degradation in audio quality. What you get is audio playback at its highest fidelity. -
Very low output impedance - 2.2 ohm
Headphones, like consumer speakers, have defined classes allowing manufacturers of amplifiers, receivers, etc to design with those standards in mind. Generally different types of headphone fall between 16-32 ohm for consumer or home applications and 600 ohm for broadcast applications. When designing the Sound Blaster E5, the engineers pushed boundaries by specially engineering the headphone amplifier circuit with a very low output impedance of 2.2 ohm. This allows the Sound Blaster E5 to accommodate both extreme ends of headphones in the market - from the most demanding high-impedance studio headphones to the most sensitive low-impedance in-ear monitors - while minimizing the introduction of distortion to audio content caused by variance in frequency response. -
Dual orientation recording with CrystalVoice technology
The Sound Blaster E5 records via built-in dual microphones with auto-orientation sensor that reacts to landscape or portrait orientation, allowing stereo recording to smartphones or tablets. The Sound Blaster E5 also features CrystalVoice technology, a suite of audio recording enhancements built into the digital signal processor (DSP) that reduces noise and provides for clear calls and voice recordings, be it from mobile phones or via Skype conferencing. Communication profiles such as A2DP, HFP and AVRCP are supported for voice calls. -
Dual headphone outputs
Dual headphone output lets you and your loved one enjoy your favorite tracks simultaneously.
- Creative Sound Blaster E5 - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB / Bluetooth
- Sound Output Mode
- Stereo
- Signal-To-Noise Ratio
- 120 dB
- System Requirements
- Apple MacOS X 10.6.8 or later, Android 2.3 or later, Apple iOS 6.x or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits)
- 1-year warranty
- Sound card
- Form Factor
- External
- Interface Type
- USB / Bluetooth
Audio Output
- Sound Output Mode
- Stereo
- 120 dB
- CrystalVoice, SBX Pro Studio, digital-to-analogue converter (DAC), built-in microphone
- 1 x audio line-in/microphone - mini-phone stereo 3.5 mm , 2 x headphones - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Tabletop stand
- Cables Included
- 1 x TOS Link cable , 1 x micro-USB cable
- OS Required
- Limited warranty - 1 year
