Get ready to enjoy some splashing fun with your audio! Weather-tested the Creative MUVO mini is also water and dust resistant, ensuring nothing stops you from enjoying your music in wild weather, or the wildest pool party! The Creative MUVO mini is designed to be small and compact for you to take it everywhere with you. Let the adventure begin! Don't underestimate the audio prowess of the Creative MUVO mini because of its size! This speaker pumps out surprisingly loud and clear stereo audio with bass deep enough to get everyone dancing to your playlist.
Poolside cool
Get ready to enjoy some splashing fun with your audio! Weather-tested the Creative MUVO mini is also water and dust resistant, ensuring nothing stops you from enjoying your music in wild weather, or the wildest pool party! -
Bring the party with you
The Creative MUVO mini is designed to be small and compact for you to take it everywhere with you. Let the adventure begin! -
Get the party started
Don't underestimate the audio prowess of the Creative MUVO mini because of its size! This speaker pumps out surprisingly loud and clear stereo audio with bass deep enough to get everyone dancing to your playlist. -
Don't let the party stop
Keep that playlist going; the Creative MUVO mini has a long battery life. When it runs out of juice, simply charge it via its Micro USB port. -
Connect wirelessly
Simply tap on the Creative Mini to pair your NFC-enabled device for fuss-free pairing. Alternatively, you can also connect your device via Bluetooth. -
Aux-in
The Creative MUVO mini comes with an integrated 3.5mm aux-in for connection to other analog audio devices. -
Toggle between your playlist and your calls
Switching between your phone calls and your playlist is so hassle-free with the Creative MUVO mini. The speaker is integrated with a built-in microphone which enables it to double up as a speakerphone. When you are done with your call, simply switch back to your playlist with the tap of a button. How easy is that?
- Creative MUVO mini - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - active
- Red
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 19 cm x 5.9 cm x 3.7 cm
- 285 g
- 1-year warranty
- Product Type
- Hands-Free Function
- Protection
- Waterproof
- Enclosure Colour
- Red
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Additional Features
- Sub Band Coding (SBC)
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: 2 x full-range driver , Speaker: Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Micro-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 2200 mAh
- 19 cm
- 5.9 cm
- 3.7 cm
- 285 g
- Limited warranty - 1 year
