Get louder audio with Creative MUVO 20! Featuring powerful drivers in an enlarged enclosure and Creative BasXPort technology, MUVO 20 delivers the biggest sound in its class. Take it anywhere with you to enjoy non-stop, high-quality wireless audio for long hours. This handy speaker also lets you charge your mobile devices via its dedicated USB port.
Your audio on the MUVO
Enjoy louder, more impact audio with Creative MUVO 20, wherever, whenever! With its built-in battery and wireless capabilities, there are simply no limits to how you can enjoy your audio. -
Cook 'n groove
Add a dash of music as your secret ingredient in your cooking! Simply pair your smartphone with MUVO 20, and you're all set to jive as you whip up a meal in your kitchen. And, even if you have your hands full cooking up a feast, you don't have to worry about missing your calls as MUVO 20 doubles up as a speakerphone for hands-free conversations. -
Kick back and relax
Immerse yourself in your movies and games with the power-packed audio of MUVO 20. With a long battery life, MUVO 20 has enough juice for a movie marathon, watching your favorite drama series, or even an extended gaming session. -
Life of the party
Liven up your party with MUVO 20's powerful audio that's comparable to that delivered by a mains-powered speaker. Its built-in battery can be conveniently recharged via the micro USB connection. And, if your gadgets run out of juice, MUVO 20 also doubles up as a backup battery pack. -
Biggest sound in its class
The MUVO 20 delivers bigger sound than most other portable speakers. It incorporates the BasXPort technology, which features an advanced dual-flared bass port tube to deliver clean and high-output bass. This technology works hand-in-hand with a pair of powerful 3" full-range drivers, housed in a large acoustic enclosure, to deliver audio acoustics that is comparable to a mains-powered speaker. -
High-quality wireless audio
Going wireless with the MUVO 20 is quick and easy. Simply tap and pair! Equipped with the aptX high-definition codec, you can be sure that the wireless audio streamed on MUVO 20 sounds as good as that from a wired connection. -
Long lasting
MUVO 20's built-in lithium-ion battery lasts hours on a single charge. You can simply recharge it via USB. -
Charge your devices
If you're running low on battery power, MUVO 20 can also be used as a backup power source to charge your mobile devices. -
NFC
For fuss-free pairing, just tap your NFC - enabled device on the speaker. -
Chat with ease
With the built-in microphone, MUVO 20 acts as a speakerphone so you can use it for hands-free mobile voice calls. It's also easy to switch between phone calls and music playback. Just press the Bluetooth button to pick up or end a call. -
Optimum baffle tilt
The MUVO 20's front panel is designed with a 12" baffle tilt to give you better audio dispersion for an optimum listening experience.
- Creative MUVO 20 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - active
- Black
- Built-in Decoders
- aptX
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 33.5 cm x 11.5 cm x 11.5 cm
- 1.02 kg
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- Black
- Enclosure Design
- Bass reflex
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Built-in Decoders
- aptX
- Controls
- Volume
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: 2 x full-range driver - 3"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
- Included Accessories
- Micro-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 10 hour(s)
- 33.5 cm
- 11.5 cm
- 11.5 cm
- 1.02 kg
- Limited warranty - 2 years
