Designed with an integrated handle and a built-in battery that lasts long hours, it's easy to take the Creative MUVO 10 wherever you go. Its large full-range drivers and BasXPort technology deliver great audio to keep your party going. It also features NFC for quick one-touch pairing with your smart devices.
Your audio on the MUVO
The Creative MUVO 10 is so versatile, it's perfect for any setting or occasion - for easy listening at the patio or in your kitchen; it's perfect for a beach outing or a picnic too. -
Cook 'n groove
Add a dash of music as your secret ingredient in your cooking! Simply pair your smartphone with MUVO 10, and you're all set to jive as you whip up a meal in your kitchen. Plus, the speaker also doubles up as a speakerphone, so you can converse hands-free when a call comes in! -
Lounge anywhere with the MUVO
The MUVO 10 comes with an integrated handle that is ergonomically designed for great portability! Together with its built-in battery, you're free to enjoy your mobile entertainment anywhere, its long battery life ensures that you have enough juice for a movie marathon, watch your favorite TV series, or even spend the afternoon gaming away. All you need to do is - sit back and enjoy. -
The great outdoors
Being extremely portable, the MUVO 10 is perfect for use outdoors. Bring it along for your picnic or camping trips to liven things up. When the MUVO 10 runs out of juice, simply recharge it via USB. -
A handle that comes in handy
With the speaker's sturdy, integrated handle, it's easy to carry it around with you wherever you go. -
Let the music play on
The built-in lithium-ion battery lasts long hours on a single charge, giving you ample juice for a day out. Then, simply recharge it via USB. -
Sheer loudness
Housed in an optimized acoustic enclosure to give it critical acoustic mass, the MUVO 10 delivers surprisingly loud and impact audio with its efficient 3" full range drivers. -
Clean bass
The advanced dual-flared bass port in MUVO 10 facilitates in the delivery of clean, loud bass. -
Excellent audio throw
The front panel is designed with a 12-degree baffle angle for better audio dispersion. -
Tap and pair
For fuss-free Bluetooth pairing, just tap your NFC-enabled device to the speaker for instant pairing. -
Bluetooth
You can also connect it wirelessly to your Bluetooth devices using the conventional method. -
Take your calls
With MUVO 10's built-in microphone, you can use it as a speakerphone to answer your calls. Switching between your phone conversations and music playback is also easy.
- Creative MUVO 10 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - active
- Blue
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 32 cm x 11.3 cm x 10.5 cm
- 967 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- Blue
- Enclosure Design
- Bass reflex
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Volume
- Additional Features
- Integrated carrying handle
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: 2 x full-range driver - 3"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Micro-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 8 hour(s)
- 32 cm
- 11.3 cm
- 10.5 cm
- 967 g
- Limited warranty - 2 years
