Creative Inspire T6300 - Speaker system - 5.1-channel - wired - 57 Watt (Total)
Quicklinx: 8FH8WS00 Mfr#: 51MF4115AA004
Be inspired by high-performance 5.1 audio with impressive bass
Let the Inspire T6300 5.1 surround speaker system elevate your movie, game and music experience to new heights! With Creative's Dual Slot Enclosure (DSE) design, the speakers are ingeniously constructed to produce louder, more pronounced mid-bass out of their compact shells. Each satellite also features the Creative Image Focusing Plate (IFP) design for accurate sonic directivity and natural tonal balance. The speaker system comes with bold front satellites, smaller rear and center satellites, plus a powerful down-firing ported subwoofer for explosive bass. It makes the perfect complement to any desktop computer. Surround yourself with the most compelling 5.1 audio experience today with the Inspire T6300!
Big sound from a compact system
To increase loudness and bass, speakers generally require fairly long and wide port tubes. The Inspire T6300 features the Creative DSE design, which enables the speakers to achieve louder and deeper playback even when constrained to a compact housing. This is made possible by separating the port tube into two separate slots and reconstructing them to fit into a tight enclosure.
Enjoy natural sounding audio
Our newly-improved Creative IFP design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy. With more natural-sounding audio, you'll feel as if the concert is performing live, right there in your room!
Powerful subwoofer with adjustable bass
Everyone likes their bass in a different way - some like explosive thumps, others prefer it light. Simply adjust the bass level of the powerful, down-firing ported subwoofer just the way you like it!
Amazing surround sound
The speaker system comes with two larger, distinctive front satellites that complement any entertainment system setting; and three smaller rear and center positional satellites for more discrete placement.
Together, they deliver accurate 5.1 positional audio during games and movies for the most realistic and amazing experience ever!
Easy access to controls
The power and volume control are integrated into one independent wired remote control for your convenience and ease of use.
  • Big sound from a compact system
  • Enjoy natural sounding audio
    The Creative IFP design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy. With more natural-sounding audio, you'll feel as if the concert is performing live, right there in your room!
  • Powerful subwoofer with adjustable bass
  • Amazing surround sound
  • Easy access to controls
Creative Inspire T6300 - speaker system - for PC
Speaker system - for PC - 5.1-channel
System Components
5 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
57 Watt
Frequency Response
50 - 20000 Hz
Amplifier
Integrated
Speaker System Details
5 x satellite speaker 7 Watt , 1 x subwoofer 22 Watt
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
57 Watt
Frequency Response
50 - 20000 Hz
Sensitivity
75 dB
Amplifier
Integrated
Controls
Power on/off, volume, bass
Speakers Included
5 x satellite speaker - 7 Watt - wired , 1 x subwoofer - 22 Watt - wired
Driver Details
Satellite speaker: high/midrange driver
Driver Details (2nd speaker)
Subwoofer: subwoofer driver
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Remote control
Remote Control
Remote control
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Satellite speaker: 8.6 cm x 9.3 cm x 17.7 cm / 274 g , Rear channel speaker: 7.2 cm x 7.9 cm x 14.7 cm / 319 g , Centre channel speaker: 14.7 cm x 7.9 cm x 7.2 cm / 258 g , Subwoofer: 17.5 cm x 26.3 cm x 22.7 cm / 2.4 kg
