Immerse yourself in true-to-life music and tighter bass tones in unmatched comfort with the Creative Aurvana Live!2. With cutting-edge driver technology and meticulous acoustic tuning, it delivers a natural and faithful audio presentation to fulfill your entertainment and communication needs.
True-to-life audio performance
Modeled after its award-winning predecessor, the Creative Aurvana Live!2 is designed to deliver true-to-life acoustic performance with tighter bass. The headset is powered by 40mm Bio-Cellulose drivers for impeccable audio while the earcups' premium protein faux leather cushions with memory-foam provide excellent seal against external noise. They also provide unmatched comfort for extended wear. -
Ultra definition audio performance
Constructed with accurate 40mm Neodymium drivers with bio-cellulose diaphragm and meticulously tuned, Aurvana Live!2 delivers audio so authentic, it's as if you're in a live performance! Bio-cellulose is a natural fiber which has extremely fine fiber and high purity. Using cutting-edge biotechnology processes, this material is compressed to produce an ultra-thin diaphragm that is ideal for headphone drivers, delivering sound velocity comparable to an aluminum or titanium diaphragm, while giving warm and delicate sound of paper ones. The result is faithful, crystal clear and detailed highs, coupled with remarkable deep and rich bass tones. -
Convenient playback and calls
The headset uses a high-purity, tangle-free, flat audio cable with an inline microphone and a one-button remote with volume adjustment for hassle-free communication on your smartphone. The cable can be detached for storage or retrofitted with another cable of your choice. -
Unmatched comfort
Padded with premium protein faux leather and memory-foam, the earcups provide you with unmatched comfort over extended periods of usage. -
Sophisticated design
Aesthetic and lightweight, the Aurvana Live!2 is styled in two alluring color options and enforced with a metal alloy headband for added durability. -
Travel ready
The flat-fold earcups is ideal for audio monitoring and convenient storage. A soft microfiber travel pouch is also included for portable convenience.
- Creative Aurvana Live!2 - headset
- Product Type
- Headset - wired
- Recommended Use
- Portable electronics, computer
- Black dark red chrome
- Headphones Form Factor
- Full size binaural
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 10 - 30000 Hz - Sensitivity 105 dB/mW
- Diaphragm Type
- Bio-cellulose
- Microphone
- On-cable
- Controls
- Volume
- Product Type
- Headset - wired
- 255 g
- Recommended Use
Audio Output
- Foldable
- Wired
- Sound Output Mode
- Stereo
- 10 - 30000 Hz
- Sensitivity
- 105 dB/mW
- Diaphragm
- Bio-cellulose - 40 mm
- Magnet Material
- Neodymium magnet
- In-Cord Volume Control
Microphone
- On-cable
- Sensitivity
- -42 dBV/Pascal
- 100 - 10000 Hz
Remote Control
- Controls
- Volume
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Detachable Cable
- Plated Connector
- Gold
- Included Accessories
- Carrying pouch, 6.3 mm (1/4") stereo adapter
- Cable Details
- Headphones cable - 1.2 m
