Product
Corsair VS Series VS450 450W 240V PSU 120mm
Quicklinx: BNT1WS00 Mfr#: CP-9020096-UK
The Corsair VS450 is a great choice if you're building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
  • Real power
    The VS450 delivers a guaranteed 450 Watts of continuous power. With 0.99 Active Power Factor Correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And, a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables.
  • Low noise, high efficiency
    The 120mm fan is thermally controlled, so it only spins at maximum speed when it's pushed hard - and even at full load, it's pretty quiet. Smart design features like this are why VS450 offers up to 85% efficiency. Your PC system will generate less heat, and you'll enjoy lower energy bills.
  • Sophisticated design
    The black powder-coated enclosure and the black-sleeved cables give any system a polished look. You're building a PC, not a battleship, and with the VS450 you can avoid that look of unpainted steel that you'll find on so many entry-level power supplies.
CORSAIR VS Series VS450 - power supply - 450 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS
1.5 kg
United Kingdom
Input Voltage
AC 200-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 2 x 6 pin PCI Express power , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties, mounting kit
Black powder coat
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ EPS12V
PSU Form Factor
ATX
Black powder coat
United Kingdom
Input Voltage
AC 200-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Max Electric Current
5 A
Power Capacity
450 Watt
Output Current
+3.3V - 16 A , +5V - 16 A , +12V - 34 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
85%
80 PLUS
MTBF
100,000 hours
Cooling System
120 mm fan
Sleeved cables, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, non-modular
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.5 kg
Shipping Width
26 cm
Shipping Depth
18 cm
Shipping Height
9.6 cm
Shipping Weight
1.64 kg
