Imagine no more emailing photos to yourself, hunting for a USB cable, or running out of room on your USB OTG compatible Android phone or tablet. Flash Voyager GO is the quick and easy way to move photos, music and videos between your mobile devices and your PCs and dramatically increase your devices' storage. The ingenious design has both a USB and a Micro-USB connector, so you can copy photos and videos to your desktop or notebook PC for safekeeping, share music and media between your PCs and your Android device, or just leave it connected to the Micro-USB port for a huge boost to your device's storage capacity.
Flash Voyager GO has both a USB 3.0 connector for your PC or Mac, and a Micro-USB connector for your Android phone or tablet. It requires a newer Android device with USB On-The-Go (also known as USB OTG) support.
- Corsair Flash Voyager GO - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Localisation
- European Union
- OS Required
- Linux, Apple MacOS X, Microsoft Windows, Android
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Compatibility
- Non-specific
- Localisation
- European Union
- Interface Type
- USB 3.0
- USB On-The-Go compatible, micro-USB connector
- Included Accessories
- Lanyard, 1 extra cap
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 3.7 mm
- Thickness
- 1.2 mm
- 0 °C
- 50 °C
