Product
Brand
Corsair Vengeance LPX 64GB 8x8GB DDR4 DIMM 288-pin 2400MHz CL14 1.2v
Quicklinx: B0NFWS00 Mfr#: CMK64GX4M8A2400C14
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance LPX - DDR4 - 64 GB: 8 x 8 GB - DIMM 288-pin
RAM memory
64 GB: 8 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL14 (14-16-16-31)
Dual channel, 8 Layers PCB heatspreader, Black PCB, quad channel, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage
1.2 V
64 GB: 8 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL14 (14-16-16-31)
Non-ECC
Voltage
1.2 V
