Product
Corsair Vengeance LPX 16GB 4x4GB DDR4 DIMM C14 Red
Reduced Price - Whilst Stocks Last!
Quicklinx: B0NBWS00 Mfr#: CMK16GX4M4A2400C14R
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
Hurry, only 1 left in stock!
£141.75 ex VAT
£170.10 inc VAT
Express delivery Delivered on Tuesday
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There's XMP 2.0 support for trouble-free automatic overclocking. And, they're available in multiple colors to match your motherboard, your components, or just your style.
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance LPX - DDR4 - 16 GB: 4 x 4 GB - DIMM 288-pin - unbuffered
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL14 (14-16-16-31)
Black heatsink, dual channel, 8 Layers PCB heatspreader, Black PCB, quad channel, Vengeance red low profile heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage
1.2 V
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL14 (14-16-16-31)
Non-ECC
Voltage
1.2 V
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-19200
Brand: Corsair
Stock Status: Clearance
Price Range Ex VAT: 100 - 150
