Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance LPX - DDR4 - kit - 16 GB: 4 x 4 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 4 x 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Bundled with
- 2 x memory fan
- Data Integrity Check
- Non-ECC
- Speed
- 3200 MHz (PC4-25600)
- Latency Timings
- CL16 (16-18-18-36)
- Dual channel, 8 Layers PCB heatspreader, Black PCB, quad channel, Vengeance red low profile heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, Corsair Vengeance Airflow Fan, unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty
- Capacity
- 16 GB: 4 x 4 GB
- Upgrade Type
- Generic
- Bundled with
- 2 x memory fan
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.35 V
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3200 MHz - 1.35 V - CL16 - 16-18-18-36
