Corsair Vengeance LPX 16GB (2x8GB) DDR4 3000MHz DIMM 288-pin
Quicklinx: BMRPWS00 Mfr#: CMK16GX4M2B3000C15
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
34 in stock
£70.31 ex VAT
£84.37 inc VAT
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance LPX - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin - unbuffered
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL15 (15-17-17-35)
Dual channel, 8 Layers PCB heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage
1.35 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-17-17-35)
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3000 MHz - 1.35 V - CL15 - 15-17-17-35
Colour Category
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-24000
Brand: Corsair
Price Range Ex VAT: 50 - 100
