Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance LPX - DDR4 - kit - 64 GB: 4 x 16 GB - DIMM 288-pin - 3600 MHz / PC4-28800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 64 GB: 4 x 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Bundled with
- Vengeance Airflow
- Data Integrity Check
- Non-ECC
- Speed
- 3600 MHz (PC4-28800)
- Latency Timings
- CL18 (18-19-19-39)
- Dual channel, 8 Layers PCB heatspreader, quad channel, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, Corsair Vengeance Airflow Fan, unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty
- Capacity
- 64 GB: 4 x 16 GB
- Upgrade Type
- Generic
- Bundled with
- Vengeance Airflow
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.35 V
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3600 MHz - 1.35 V - CL18 - 18-19-19-39
- Colour Category
- Black
