Corsair Vengeance 32GB (4x8GB) DDR4 4000MHz CL19 DIMM Memory
Quicklinx: CQ2MWS00 Mfr#: CMK32GX4M4B4000C19R
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 4000MHz
Data Integrity: Non-ECC
£390.19 ex VAT
£468.22 inc VAT
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance LPX - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin - unbuffered
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Bundled with
Vengeance Airflow
Data Integrity Check
Non-ECC
Speed
4000 MHz (PC4-32000)
Latency Timings
CL19 (19-23-23-45)
Dual channel, 8 Layers PCB heatspreader, quad channel, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, Corsair Vengeance Airflow Fan, unbuffered
Voltage
1.35 V
32 GB: 4 x 8 GB
Upgrade Type
Generic
Bundled with
Vengeance Airflow
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19 (19-23-23-45)
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 4000 MHz - 1.35 V - CL19 - 19-23-23-45
Colour Category
Red
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 4000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL19
Standard: PC4-32000
Brand: Corsair
Price Range Ex VAT: 300 - 500
