Proudly display your headset with the ST100 RGB Premium Headset Stand, featuring premium aluminum construction and customizable RGB lighting. Built-in 3.5mm analog input enables full range stereo or 7.1 surround sound for an immersive, multi-channel audio experience. Easy access, dual USB 3.1 inputs provide improved charging power and faster data speeds for your headset, phone, and other devices while the non-slip, rubberized base provides stability and protection for your desk.
- CORSAIR Gaming ST100 RGB Premium Headset Stand - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB 3.1 Gen 1
- 12 cm x 12 cm x 25 cm
- 700 g
- Localisation
- Europe
- Sound Output Mode
- Stereo
- DAC Resolution
- 16-bit
- Sample Rate
- 48 kHz (max)
- 2-year warranty
- Sound card
- Form Factor
- External
- Interface Type
- USB 3.1 Gen 1
- 12 cm
- 12 cm
- 25 cm
- 700 g
- Localisation
- Europe
Audio Output
- Sound Output Mode
- Stereo
- DAC Resolution
- 16-bit
- Sample Rate
- 48 kHz (max)
- USB bus-powered, virtual 7.1 channel surround mode, 2-port USB hub, RGB lighting, non-slip rubberised base
- 1 x audio - mini-phone 3.5 mm 4-pole , 2 x USB 3.1 Gen 1 - 9 pin USB Type A , 1 x USB 3.1 Gen 1 - Micro-USB Type B
- Cables Included
- 1 x micro-USB cable - 1.8 m
- Limited warranty - 2 years
