Corsair SP120 RGB LED, 3-Pack Static Pressure Fan with Controller
Quicklinx: CCLJWS00 Mfr#: CO-9050061-WW
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
  • High static pressure cooling with led illumination
    Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans.
  • Designed for restricted spaces
    Air Series fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source.
CORSAIR Air Series LED SP120 RGB High Performance - case fan
Case fan
Packaged Quantity
3 (specifications are for single item)
Package Content
Mounting screws for case fans, 6-port RGB LED hub, fan RGB LED controller
White, blue, yellow, red, green, orange, violet
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1400 rpm
Air Flow
52 cfm
Noise Level
26 dBA
Power Connector
3-pin plug
Custom-molded fan blades, RGB LED x4
Packaged Quantity
Case fan
Package Content
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1400 rpm
Air Flow
52 cfm
Air Pressure
1.45 mm
Noise Level
26 dBA
Power Connector
3-pin plug
Operation Voltage
7 - 13.2 V
Mounting Kit
Included
Limited warranty: - 2 years
