Product
Corsair SP120 PWM Quiet Dual Pack 120mm Fan
Quicklinx: C78PWS00 Mfr#: CO-9050012-WW
Cooling today's high-performance PCs is a complex task, and a single fan design can't meet every need. The fan you use to pull hot air out of your case might not be the best fan to mount flush against a heatsink or radiator.
Static pressure is the measure of how well a fan can push air in this type of highly restrictive environment, and this is where the SP120 excels. It's an ideal solution for radiator and heatsink use, as well as drive bay intakes, and other locations where you're mounting a fan directly adjacent to a heat source.
CORSAIR Air Series SP120 Quiet Edition High Static Pressure - case fan
Case fan
Packaged Quantity
2 (specifications are for single item)
Package Content
Mounting screws for case fans, 3 replaceable colour rings
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1450 rpm
Air Flow
37.85 cfm
Noise Level
23 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, rubberised corners
2 years warranty
Packaged Quantity
Case fan
Package Content
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1450 rpm
Air Flow
37.85 cfm
Air Pressure
1.29 mm
Noise Level
23 dBA
Power Connector
4-pin fan connector
Operation Voltage
7 - 12 V
Rated Current
0.08 A
