Corsair SF600 600W High Performance SFX 80 Plus Gold PSU
Quicklinx: C0QXWS00 Mfr#: CP-9020105-UK
SF series power supplies bring legendary Corsair performance and reliability to the SFX small form factor standard. They have the features found in full-size high performance power supplies, with certification for 80 PLUS Gold efficiency, superior voltage regulation, Zero RPM mode for virtually silent operation, and 105°C All Japanese capacitors for better reliability.
  • 80 PLUS Gold certified
    If you're building a small system that's going to see a lot of use, low heat generation and high efficiency are essential. SF series power supplies operate at greater than 90% efficiency at 50% load on 115 V circuits.
  • SFX form factor
    SF series is designed to the SFX power supply specification for high performance small form factor systems.
  • Fully modular cable set
    The detachable DC cables make builds and upgrades easy, with clean, great-looking results. Use only the power cables you need lets you save valuable internal space and can improve system airflow.
  • 100% all Japanese 105°C capacitors
    Premium internal components ensure solid power delivery and long term reliability.
  • Zero RPM fan mode
    Building a silent PC? SF Series power supplies are so efficient that the fan doesn't need to spin at low to medium loads.
CORSAIR SF Series SF600 - power supply - 600 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92 / SFX12V
80 PLUS Certification
80 PLUS Gold
860 g
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power
Cooling System
92 mm fan
Case badge, cable ties, cable bag
12.5 cm x 10 cm x 6.3 cm
7 years warranty
PSU Form Factor
SFX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 50 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
90%
Modular Cable Management
80 PLUS Gold
MTBF
100,000 hours
Cooling System
92 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fully modular
UL, TUV, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, China RoHS, RCM
Limited warranty - 7 years
12.5 cm
10 cm
6.3 cm
860 g
Shipping Width
18 cm
Shipping Depth
24.7 cm
Shipping Height
10.5 cm
Shipping Weight
1.6 kg
