Product
Brand
Corsair SF450 450W High Performance SFX 80 Plus Gold PSU
Clearance!
Clearance
Quicklinx: C0QWWS00 Mfr#: CP-9020104-UK
SF series power supplies bring legendary Corsair performance and reliability to the SFX small form factor standard. They have the features found in full-size high performance power supplies, with certification for 80 PLUS Gold efficiency, superior voltage regulation, Zero RPM mode for virtually silent operation, and 105°C All Japanese capacitors for better reliability.
CORSAIR SF Series SF450 - power supply - 450 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92 / SFX12V
80 PLUS Certification
80 PLUS Gold
860 g
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power
Cooling System
92 mm fan
Case badge, cable ties, cable bag
12.5 cm x 10 cm x 6.3 cm
7 years warranty
PSU Form Factor
SFX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output Current
+3.3V - 15 A , +5V - 20 A , +12V - 37.5 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
90%
Modular Cable Management
80 PLUS Gold
MTBF
100,000 hours
Cooling System
92 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fully modular
UL, TUV, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, China RoHS, RCM
Limited warranty - 7 years
12.5 cm
10 cm
6.3 cm
860 g
Shipping Width
18 cm
Shipping Depth
24.7 cm
Shipping Height
10.5 cm
Shipping Weight
1.6 kg
