RMx Series™ RM850x — 850 Watt 80 PLUS® Gold Certified Fully Modular PSU
Gold-certified efficiency with extremely tight voltage regulation to deliver superior performance
Corsair RMx series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they’re a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
80 PLUS Gold certified
Gold certification ensures high efficiency operation for less excess heat and lower operating costs.
100% Japanese 105°C capacitors
Premium internal components ensure solid power delivery and long term reliability.
Zero RPM Fan Mode
Since the fan doesn’t turn on until it’s needed, you’ll enjoy virtually silent operation at low and medium loads.
Seven year warranty
Your guarantee of reliable operation that will last across several system builds.
Fully modular cable set
Installation is faster, since you can mount the power supply in the case first, and then attach only the cables you need.
Technical Information:
80 PLUS® Gold efficiency, delivering 90% energy efficiency at real world load conditions
ZeroRPM mode for fanless operation at low loads and outstanding noise reduction
135mm thermally controlled fan spins up as needed
Fully modular cables for easy installation, less clutter, and helps maximize airflow through your computer’s chassis
Engineered to meet maximum power output at a server-grade 50°C temperature rating
Over-voltage protection, under-voltage protection, short circuit protection, over power protection, and over temperature protection provide maximum safety to your critical system components
Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH
Gold certification ensures high efficiency operation for less excess heat and lower operating costs. -
Premium internal components ensure solid power delivery and long term reliability. -
Zero RPM fan mode
Since the fan doesn't turn on until it's needed, you'll enjoy virtually silent operation at low and medium loads. -
- CORSAIR RMx Series RM850x - power supply - 850 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 1.985 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 4 PIN internal power , 10 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector , 6 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties
- 15 cm x 18 cm x 8.6 cm
- 10 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 70.8 A , -12V - 0.8 A , +5VSB - 3 A
- 80 PLUS Gold
- Cable ties
- Cables Included
- Power cable kit
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, fully modular
- CSA, UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU-TR
- Limited warranty - 10 years
- 15 cm
- 18 cm
- 8.6 cm
- 1.985 kg
- Shipping Width
- 22.5 cm
- Shipping Depth
- 39.2 cm
- Shipping Height
- 15 cm
- Shipping Weight
- 3.9676 kg
