Corsair RMX Series RM1000x 1000W High Performance 80 Plus Gold PSU
Quicklinx: BNZXWS00 Mfr#: CP-9020094-UK
Power Rating: 1000Watt, 1000Watt
19 in stock
£136.94 ex VAT
£164.32 inc VAT
RMx Series™ RM1000x — 1000 Watt 80 PLUS® Gold Certified Fully Modular PSU
Gold-certified efficiency with extremely tight voltage regulation to deliver superior performance
Corsair RMx series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they’re a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
80 PLUS Gold certified
Gold certification ensures high efficiency operation for less excess heat and lower operating costs.
100% Japanese 105°C capacitors
Premium internal components ensure solid power delivery and long term reliability.
Zero RPM Fan Mode
Since the fan doesn’t turn on until it’s needed, you’ll enjoy virtually silent operation at low and medium loads.
Seven year warranty
Your guarantee of reliable operation that will last across several system builds.
Fully modular cable set
Installation is faster, since you can mount the power supply in the case first, and then attach only the cables you need.
Technical Information:
80 PLUS® Gold efficiency, delivering 90% energy efficiency at real world load conditions
ZeroRPM mode for fanless operation at low loads and outstanding noise reduction
135mm thermally controlled fan spins up as needed
Fully modular cables for easy installation, less clutter, and helps maximize airflow through your computer’s chassis
Engineered to meet maximum power output at a server-grade 50°C temperature rating
Over-voltage protection, under-voltage protection, short circuit protection, over power protection, and over temperature protection provide maximum safety to your critical system components
Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH
  • 80 PLUS Gold certified
  • Japanese 105°C capacitors
  • Zero RPM fan mode
    Since the fan doesn't turn on until it's needed, you'll enjoy virtually silent operation at low and medium loads.
  • Fully modular cable set
CORSAIR RMx Series RM1000x - power supply - 1000 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.003 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 11 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector , 8 x 8 pin PCI Express power with detachable 2 pin section
Cooling System
135 mm fan
Cable ties
15 cm x 18 cm x 8.6 cm
10 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 83.3 A , -12V - 0.8 A , +5VSB - 3 A
Modular Cable Management
80 PLUS Gold
Cable ties
Power cable kit
MTBF
100,000 hours
Cooling System
135 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, fully modular
CSA, UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU-TR
Limited warranty - 10 years
15 cm
18 cm
8.6 cm
2.003 kg
Shipping Width
22.5 cm
Shipping Depth
39.2 cm
Shipping Height
15 cm
Shipping Weight
4.2716 kg
Brand: Corsair
Price Range Ex VAT: 100 - 150
