Corsair RM650i SERIES 650w 80+ Gold Modular PSU
Quicklinx: BDYDWS00 Mfr#: CP-9020081-UK
Corsair RMi series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. Corsair Link Digital makes it easy monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
  • 100% Japanese 105°C capacitors
    Premium internal components ensure solid power delivery and long term reliability.
  • Zero RPM fan mode
    The superior energy efficiency of the RMi Series allows for the fan to remain off at low to medium loads for virtually silent operation. And when you're pushing it hard, the thermally controlled fan adjusts its speed to provide optimal cooling with minimal noise.
  • Configurable +12V rail
    It's your choice - run it in the default multi-rail +12V mode, or toggle single-rail operation.
  • The power of Corsair Link Digital
    The advanced desktop application lets you monitor and log fan speed, voltages and power consumption, as well as control fan speed and configure +12V rail operation.
CORSAIR RMi Series RM650i - power supply - 650 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
1.672 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 54 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
135 mm fan
Cable ties, cable bag
15 cm x 16 cm x 8.6 cm
10 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
Efficiency
90%
80 PLUS Gold
Power cable kit
MTBF
100,000 hours
Cooling System
135 mm fan
Corsair Link, fan speed monitoring, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fluid dynamic bearing cooling fan, fully modular
CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, China RoHS, RCM
Limited warranty - 10 years
50 °C
15 cm
16 cm
8.6 cm
1.672 kg
