Corsair RMi series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. Corsair Link Digital makes it easy monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
100% Japanese 105°C capacitors
Premium internal components ensure solid power delivery and long term reliability. -
Zero RPM fan mode
The superior energy efficiency of the RMi Series allows for the fan to remain off at low to medium loads for virtually silent operation. And when you're pushing it hard, the thermally controlled fan adjusts its speed to provide optimal cooling with minimal noise. -
Configurable +12V rail
It's your choice - run it in the default multi-rail +12V mode, or toggle single-rail operation. -
The power of Corsair Link Digital
The advanced desktop application lets you monitor and log fan speed, voltages and power consumption, as well as control fan speed and configure +12V rail operation.
- CORSAIR RMi Series RM650i - power supply - 650 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 1.672 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 54 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties, cable bag
- 15 cm x 16 cm x 8.6 cm
- 10 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- Efficiency
- 90%
- 80 PLUS Gold
- Cables Included
- Power cable kit
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Corsair Link, fan speed monitoring, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fluid dynamic bearing cooling fan, fully modular
- CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, China RoHS, RCM
- Limited warranty - 10 years
- 50 °C
- 15 cm
- 16 cm
- 8.6 cm
- 1.672 kg
