Corsair Raptor HS30-Y Gaming Headset
Quicklinx: 9TB3WS00 Mfr#: CA-9011121-EU-Y
Great gaming sound with a comfortable, closed-back design
The Corsair Raptor HS30 gaming headset is ergonomically designed for better audio quality and the comfort you need to keep your head in the game. The 40mm neodymium audio drivers are enclosed in padded, circumaural earpads that fit around your ears so they're more comfortable and help block distractions. And, they're closed back, so your gaming won't distract anybody, either. The HS30 also has a padded headband, and a noise cancelling microphone that screens out background noise.
40mm neodymium drivers
Enjoy realistic audio reproduction with higher sensitivity, greater detail, and lower distortion.
Closed-back, circumaural padded earcups
The earcups block out distracting background noise, so you can keep your head in the game. Closed-back construction helps reduce noise leakage, to help make sure that your gaming won't bother anybody around you.
Noise-cancelling microphone
The microphone automatically reduces background noise, so you'll be heard loud and clear.
Compatible with PC, Mac, PlayStation 4, phones, and tablets
The modular cabling system lets you use the HS30 just about anywhere. The 4-pole 3.5mm connector has integrated audio input and microphone output, for connecting to mobile phones, tablets, PS4 controllers, and newer desktop and notebook computers. Or, use the included Y adapter to split it into separate 3.5mm headphone and microphone connectors for universal compatibility.
  • 40mm Neodymium drivers for better audio quality
    The large diameter drivers are equipped with high-sensitivity magnets for better sound with lower distortion.
  • Circumaural, closed-back design
    The earcups fit around the ears to help block distracting environmental noise, and the solid outer shell helps prevent bothering others when you're playing or listening.
  • Noise canceling microphone
    The microphone automatically screens out background noise, so you can be heard clearly.
  • Padded earcups and headband
    Extra comfort, so you can keep your head in the game longer without your gear getting in the way.
  • Dual 3.5mm audio connectors for compatibility
    The HS30 works with any PC or Mac with standard 3.5mm connectors for audio output and microphone input. It works with both sound cards and built-in audio connectors, on both desktop PCs and notebooks and laptops.
CORSAIR Raptor HS30 Analog Gaming - headset
Headset - wired
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Controls
Volume
Headset - wired
Audio Output
Full size
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Sensitivity
-42 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
Controls
Volume
Connector Type
Audio line-in / headphones (mini-phone 3.5 mm 4-pole)
Cable Details
Headset cable - 1.8 m , Mini-phone 3.5 mm 4-pole to 2 x mini-phone 3.5 mm cable
