Corsair Obsidian 750D Full Tower ATX Case
Quicklinx: 906GWS00 Mfr#: CC-9011035-WW
Case Form Factor: Tower
Motherboard Form Factor: Extended ATX
Colour: Black
Hurry, only 1 left in stock!
£105.47 ex VAT
£126.56 inc VAT
The Obsidian Series 750D full tower PC case combines generous expansion flexibility, room for advanced cooling options, and fast and easy builds and upgrades. It has a clean, elegant exterior that dispenses with arbitrary plastic add-ons in exchange for the beauty of brushed aluminum and solid steel. This rigid, rugged exterior surrounds a frame that has ample room for high-performance components and the sophisticated cooling you'll need if you're going to push those components to their limits. And, it incorporates a host of clever system builder-focused features, because building a system should be straightforward, trouble-free, and even fun.
  • Generous expansion room for building high-performance systems.
  • Beautiful brushed aluminum fascia makes an elegant design statement.
  • Full side panel window to view your components.
  • Tool-free SSD, Hard Drive, and Optical Drive installation.
  • Includes three AF140L fans, with room for up to eight fans.
  • Modular drive cage system for highly customizable layouts.
  • Two modular drive cages house three 3.5" or 2.5" drives each.
  • Four tool-free dedicated SSD cages, sideways mounted.
  • Designed for fast and straightforward builds.
  • Two USB 3.0 and two USB 2.0 front panel connectors, plus headphone and microphone.
  • Easily accessed front, top, and PSU dust filters.
  • Excellent cable routing with rubber grommets for clean builds.
  • Nine expansion slots for multiple PCI-E devices or large motherboards
  • Maximum CPU Cooler Height 170mm
  • Maximum GPU Length 450mm
Radiator and fan compatibility compatibility
  • Top: 3 x 120mm or 2 x 140mm
  • Front: 2 x 140mm or 2 x 120mm (2 x 140mm included)
  • Bottom: 2 x 120mm
  • Rear: 1 x 140mm or 120mm (140mm included)
  • The room you need when you're getting serious
    Nine PCI-E expansion slots support double and triple GPUs. There's room for up to ten drives, and four USB ports on the brushed aluminum front panel.
  • Your system, your cooling
    The three included Corsair AF140L high-airflow 140 mm intake and exhaust fans are custom engineered to deliver excellent airflow with less unnecessary turbulence and noise. You can mount up to eight fans, with room for dual radiators on the bottom, front, and top.
  • Take control of your storage
    There are four separate mounting locations for the drive cages, and if you're moving to 100% solid-state, you can remove the 3.5" cages entirely and use the four side-mounted 2.5" cages.
  • Designed for fast, straightforward builds
    The side panels and expansion slots use thumb screws, and storage installation is tool-free. A center-post standoff holds the motherboard in place while you secure it, and the dust filters are easily accessible and removable. The cable routing system has multiple cutouts with rubber grommets for superior airflow and a cleaner look, and the CPU backplate cutout lets you install or upgrade your CPU cooling without removing the motherboard.
CORSAIR Obsidian Series 750D - tower - extended ATX
System cabinet
Tower
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Windowed side panel, screwless drive bays, removable dust filter, meshed top
No power supply
Specification Compliance
ATX
23.5 cm x 54.6 cm x 56 cm
9.7 kg
Tower
Max Mainboard Size
Extended ATX
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
3
Product Material
Steel, acrylic, brushed aluminium
Cooling System
Top: 120 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported , Front: 140 mm fan x 2 / 2 x 120/140 mm fan supported , Bottom: 120 mm fan mount x 2 , Rear: 140 mm fan x 1 / 1 x 120/140 mm fan supported
CPU Cooler Max Height
170 mm
Video Card Max Length
450 mm
Power Supply Max Length
220 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 4 (total) / 4 (free) x internal - 2.5"
Expansion Slots
9
2 x USB 2.0 , 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
No power supply
23.5 cm
54.6 cm
56 cm
9.7 kg
Colour: Black
Brand: Corsair
Stock Status: While stocks last
Stock Status: Clearance
