The Corsair Neutron Series XTi SSD meets the needs of the most discerning PC gaming enthusiasts and content creation professionals alike.
The most powerful available solution for PC users seeking ultra-fast transfer speeds, outstanding responsiveness and consistently fast random read/write performance in a solid-state drive.
Backed up by expanded cache, end-to-end data path protection, enhanced error correction and power loss protection, the Neutron Series XTi SSD secures your drive for an ultra-consistent and reliable experience.
Hardcore PC gamers and content creation professionals who need to move large amounts of data fast and error free, know they’re in good hands with the Neutron Series XTi SSD.
High performance quad-core SSD controller
Features a dedicated quad-core processor for top tier performance with low command latency and sustained performance achieved by utilizing unique quad-core controller. -
Consistent performance
Very high sustained transfer rates enabled by expanded cache make it possible to capture and edit professional Full HD and 4K uncompressed video in real-time, as well as play PC games with absolute maximum detail levels. -
Low power consumption
95% less power consumption than standard HDDs means better energy efficiency for your desktop machine and longer battery life for your laptop. Also includes support for DEVSLP (device sleep). -
Exceptional transfer speeds
The SATA 6Gb/s effectively saturates the SATA 6Gbp/s interface, SSD providing a sequential read of up to 560Mb/s, sequential write of up to 540Mb/s, 4KB random reads of up to 100K IOPS and 4K random writes of up to 90K IOPS. -
End-to-end data path protection
ETEP protects the entire data path within the SSD controller. From the host to the NAND gate, ensuring data is protected against corruption.
- CORSAIR Neutron Series XTi - SSD - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Enhanced Error Correction Code, Power Loss support, DEVSLP SATA low power mode, End-to-end data path protection, Toggle NAND Technology, S.M.A.R.T.
- 7 mm
- 55 g
- 5-year warranty
- Capacity
- 480 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 7 mm
- 55 g
Performance
- SSD Endurance
- 320 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 540 MBps (write)
- Maximum 4KB Random Write
- 90000 IOPS
- Maximum 4KB Random Read
- 100000 IOPS
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Power Consumption
- 3 mW (DevSleep)
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8.1, Windows 10
- Included Accessories
- 3.5-inch bay adapter
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 500 g
- Shock Tolerance (non-operating)
- 500 g
