Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Magnetic bearing
Harnesses magnetic levitation technology to provide lower noise, higher performance, and a longer lifespan. -
Custom rotor design
Delivers the perfect balance between high static pressure and high airflow, operating flawlessly in the challenging environments. -
Extensive control range
A high control range gives you total control between low noise and absolute performance.
- Corsair ML Series ML140 PRO LED Premium Magnetic Levitation - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans
- Blue
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Magnetic bearing
- Rotation Speed
- 400-2000 rpm
- Air Flow
- 20-97 cfm
- Noise Level
- 16 - 37 dBA
- Power Connector
- 4-pin fan connector
- Pulse-width modulation (PWM) support, blue LED
- 5 years warranty
- Product Type
- Case fan
- Package Content
- Blue
Heatsink & Fan
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Magnetic bearing
- Rotation Speed
- 400-2000 rpm
- Air Flow
- 20-97 cfm
- Air Pressure
- 0.2-3.0 mm
- Noise Level
- 16 - 37 dBA
- Power Connector
- Rated Current
- 0.276 A
- Limited warranty - 5 years
