Product
Corsair ML120 LED ML Series 120mm Magnetic RPM Fan Blue
Quicklinx: C7H3WS00 Mfr#: CO-9050043-WW
Type: Case Fan
£16.72 ex VAT
£20.06 inc VAT
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
  • Magnetic bearing
    Harnesses magnetic levitation technology to provide lower noise, higher performance, and a longer lifespan.
  • Custom rotor design
    Delivers the perfect balance between high static pressure and high airflow, operating flawlessly in the challenging environments.
  • Extensive control range
    A high control range gives you total control between low noise and absolute performance.
Corsair ML Series ML120 PRO LED Premium Magnetic Levitation - case fan
Case fan
Package Content
Mounting screws for case fans
Blue
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Magnetic bearing
Rotation Speed
400-2400 rpm
Air Flow
12-75 cfm
Noise Level
16 - 37 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, blue LED
5 years warranty
Case fan
Package Content
Blue
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Magnetic bearing
Rotation Speed
400-2400 rpm
Air Flow
12-75 cfm
Air Pressure
0.2-4.2 mm
Noise Level
16 - 37 dBA
Power Connector
4-pin fan connector
Rated Current
0.299 A
Limited warranty - 5 years
Type: Case Fan
Brand: Corsair
Price Range Ex VAT: 0 - 50
