Intuitive RGB backlighting modes, 6 dedicated macro keys, multi-key anti-ghosting and media controls provide the customization and control essential for victory. The K55 RGB is your first step towards enhanced performance.
Dynamic lighting
Three-zone backlighting for immersive lighting effects. -
Programmable
6 fully-programmable macro keys. -
Multimedia controls
Directly access your audio without interrupting your game. -
Quiet keys
Minimum noise and satisfying feel. -
Multi-key anti-ghosting
Simultaneous commands register the way you intended. -
Detachable soft rubber wrist rest
Additional comfort to support marathon gaming sessions. -
Windows key lock mode
Ensures interruption-free game. -
Keyboard tilt adjustment
Enable comfort for long play sessions.
- CORSAIR Gaming K55 RGB - keyboard - UK Input Device
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Qty
- 6
- Hot Keys Function
- Mute, macros buttons, play/pause, stop, previous track, next track, volume -, volume +, Windows key lock
- Numeric Keypad
- Gaming
- 48.02 cm x 16.63 cm x 3.46 cm
- 822 g
- 2-year warranty
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Hot Keys Qty
- 6
- Hot Keys Function
- UK
- Simultaneous Key Press Quantity
- 8
- Gaming
- Palm Rest
- Numeric keypad
- 48.02 cm
- 16.63 cm
- 3.46 cm
- 822 g
- Included Accessories
- Soft rubber wrist rest
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10
- Limited warranty - 2 years
