Corsair K55 + Harpoon RGB Gaming Keyboard/Mouse Combo
Quicklinx: D8YFWS00 Mfr#: CH-9206115-UK
Wired / Wireless: Wired
Compatibility: PC
£59.59 ex VAT
£71.50 inc VAT
The K55 combo is your first step toward victory. Together, this duo comes packed with the essential features to step up your game.
  • Programmable macro keys
    Assign single keystrokes or complex multi-key combos to any of the dedicated macro keys, without any additional software required to be installed.
  • Dedicated volume and multimedia controls
    Adjust your audio without interrupting your game with direct access to volume and media playback.
  • Quiet and responsive keys
    Minimum noise and satisfying feel without sacrificing performance.
  • Lightweight design
    Designed to fit naturally in your hand and support multiple grip styles.
CORSAIR Gaming K55 + HARPOON RGB Combo - keyboard and mouse set - UK English
Keyboard and mouse set
Backlit
RGB
USB
Input Device
Keyboard
Layout
UK English
Hot Keys Qty
6
Hot Keys Function
Mute, play/pause, stop, previous track, next track, volume -, volume +, Windows key lock
Numeric Keypad
Pointing Device
Mouse - wired - optical - left-handed
Buttons Qty
6
Backlit
RGB
USB
Dimensions (WxDxH) / Weight
Keyboard: 48.02 cm x 16.63 cm x 3.46 cm / 907 g
Input Device
Keyboard
Hot Keys Qty
6
Hot Keys Function
Layout
UK English
Simultaneous Key Press Quantity
8
Palm Rest
Numeric keypad
Pointing Device
Mouse - wired
Buttons Qty
6
Movement Detection Technology
Optical
Movement Resolution
6000 dpi
Orientation
Left-handed
Backlit
RGB
Soft rubber wrist rest
Microsoft Windows Vista / 7 / 8 / 10
Compatibility: PC
Brand: Corsair
Price Range Ex VAT: 50 - 100
