Corsair Hydro Series H80i v2 Extreme Performance Liquid CPU Cooler
Quicklinx: BYQPWS00 Mfr#: CW-9060024-WW
Type: Water Cooling
25 in stock
£86.76 ex VAT
£104.11 inc VAT
Hydro Series H80i v2 is an all-in-one liquid CPU cooler with an extra-thick 120mm radiator and dual SP120L PWM fans for cooling that’s far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the selfcontained design of the H80i v2 makes it easy for you to protect your valuable CPU.
The H80i v2 has Corsair Link built in. Just attach the included cable to a USB header on your motherboard and download the free Corsair Link software, and you can monitor CPU and coolant temperatures, adjust fan speeds, and customize the LED lighting directly from your desktop.
  • Extra-thick 120mm radiator: A depth of 49mm provides more surface are for rapid cooling.
  • Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
  • Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
  • Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
  • User replaceable inserts: Change the color of your cooler to match your system with the user-replaceable inserts on the radiator and pump cap (Sold Separately).
Includes:
  • Corsair Hydro Series H80i v2 High Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP120L High Torque 120mm fans
  • USB cable for Corsair Link. Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
  • Extra-thick radiator
    The radiator works with standard fan mounts for wide compatibility, and delivers increased cooling surface area and faster, more efficient cooling.
  • Customized cooling performance
    You can select the speed of the dual PWM fans via the Corsair Link control panel or any standard fan speed utility. And, you have possibilities: use just one fan to save space, or install both in a push-pull configuration for extra cooling efficiency.
    Attach the included Corsair Link cable to a USB header on your motherboard to unlock even more power. You can customize cooling performance, monitor coolant and CPU temperatures, and change the color of the RGB LED lighting from the default white to match your system or to change color based on temperature readings and other inputs.
  • High-performance CPU cooling made simple
    The H80i v2 is a closed loop design that comes pre-filled. It includes a modular, tool-free mounting bracket for faster installation, and it features improved cold plate and pump designs for highly tuned efficiency.
CORSAIR Hydro Series H80i v2 High Performance Liquid CPU Cooler processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Noise Level
37.7 dBA
Pulse-width modulation (PWM) support
Corsair Link
5-year warranty
Heatsink & Fan
Compatible With
Security Cable Lock
Heatsink Material
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Air Pressure
4.65 mm
Noise Level
37.7 dBA
Mounting Kit
Included
Corsair Link
Limited warranty - 5 years
Type: Water Cooling
Brand: Corsair
Price Range Ex VAT: 50 - 100
