Corsair Hydro Series H55 Quiet CPU Cooler
Quicklinx: 8CXGWS00 Mfr#: CW-9060010-WW
Type: CPU Cooler
24 in stock
£60.67 ex VAT
£72.80 inc VAT
Compatible with 4th generation Intel® Core™ series processors
The easy performance upgrade for your Intel CPU Your PC will run cooler and quieter when you replace your CPU's standard heatsink with a Hydro Series H55. Installation is straightforward. If you can get to the back of your PC's motherboard, you can install an H55. All you'll need is a screwdriver. Great for smaller cases The compact components and flexible tubing make H55 easy to install even if you're cramped for space.
Product Features
  • Pre-filled, never needs refilling
  • Tool-free mounting bracket
  • Low-noise, low-speed 120mm fan
  • Flexible rubber hose for installation in tight spaces
  • Low-profile pump for easy installation and better airflow
  • Micro fin copper cold plate for superior heat dissipation
  • Low-profile black aluminum heat exchanger
  • Intel® Mounting hardware for LGA 115x, 1366, and 2011
  • AMD® Mounting hardware for AM2, AM3, and FM1
Specs
  • Coldplate Material Copper Micro Fin
  • Tubing Material Low Evaporation Rubber
  • Radiator Material Aluminum
  • Radiator Size 120mm x 152mm x 27mm
  • Fan(s) included (1) 120mm x 25mm
  • Fan Max Speed 1700 RPM +/- 10%
  • Fan Airflow 57 CFM
  • Fan Static Pressure 1.9 mm H20
  • Fan Noise Level 30.32 dBA
  • Intel Mounting Hardware LGA 115x, 1366, 2011
  • AMD Mounting Hardware AM2, AM3, FM1
  • The easy CPU performance upgrade
    Your PC will run cooler and quieter when you replace your CPU's standard heatsink with a Hydro Series H55. Installation is straightforward: if you can get to the back of your PC's motherboard, you can install an H55. All you'll need is a screwdriver.
  • Great for smaller cases
    The compact components and flexible tubing make Hydro Series H55 easy to install even if you're cramped for space. It allows you to improve your CPU's cooling efficiency even in most compact cases - as long as your case has a 120 mm fan mount near the CPU, H55 will probably fit.
  • Self-contained cooling system
    Hydro Series H55 comes pre-filled, and never needs refilling or priming.
  • Tool-free mounting bracket kit
    The modular design makes installation simpler, and it's compatible with Intel and AMD processors.
  • Low-noise, low-speed 120 mm fan
    The low speed and wide diameter reduces noise levels over the smaller, faster fans used on stock CPU coolers. The three-pin connector is compatible with fan controllers.
  • Low permeability rubber tooling
    Minimal coolant evaporation helps ensure long life, and the resilient rubber offers both high flexibility and excellent leak protection.
  • Low-profile pump
    The pump unit provides high-speed circulation without taking a lot of space. This makes installation easier, and helps improve your case's airflow.
  • Micro-fin copper cold plate with pre-applied thermal compound
    Copper has excellent thermal transfer characteristics, and the fin design is optimized for efficient heat exchange.
    The low-profile design reduces the airflow requirement, which helps make H55 quieter. The small size also allows for easier installation and improved compatibility, and the black finish looks great.
CORSAIR Hydro Series H55 Quiet CPU Cooler processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1700 rpm
Air Flow
57 cfm
Noise Level
30.32 dBA
5-year warranty
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1700 rpm
Air Flow
57 cfm
Air Pressure
1.9 mm
Noise Level
30.32 dBA
Mounting Kit
Included
Limited warranty - 5 years
Resources
The following resources are available for the Corsair Hydro Series H55 Quiet CPU Cooler
Type: CPU Cooler
Brand: Corsair
Price Range Ex VAT: 50 - 100
