The Hydro Series H110i GT is an extreme performance, all-in-one liquid CPU cooler for cases with 280mm radiator mounts. The 280mm radiator and dual SP140L PWM fans provide the excellent heat dissipation you need for highly overclocked CPUs. It's Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
Corsair Hydro Series CPU coolers give you the power of liquid cooling in a compact, easy-to-install package. They offer superior cooling for higher overclocking performance, without the complexity of traditional water cooling kits.
280mm radiator
The secret to fast, efficient cooling is maximizing cooling surface area. If your PC case has dual 140mm fan mounts spaced for a 280mm radiator, the H110i GT lets you take advantage of your case's full cooling potential. -
Advanced SP140L PWM fans
The included 140mm fans are custom-designed for high static pressure air delivery with minimum turbulence and noise. They're PWM controlled, so you can customize the fan speed to find the optimal balance of cooling and noise. -
Built-in Corsair Link
Attach the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link software to unlock even more power. You can customize cooling performance, monitor coolant and CPU temperatures, and change the color of the RGB LED lighting from the default white to match your system, or to change color based on temperature readings and other inputs. -
High-performance CPU cooling made simple
The H110i GT is a closed loop design that comes pre-filled. It includes a modular, tool-free mounting bracket for faster installation, and it features improved coldplate and pump designs for highly tuned efficiency.
- CORSAIR Hydro Series H110i GT Extreme Performance Liquid CPU Cooler - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Compatibility
- LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket, LGA1200 Socket
- Heatsink Material
- Copper
- Fans Qty
- Dual
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2100 rpm
- Air Flow
- 113 cfm
- Noise Level
- 43 dBA
- Pulse-width modulation (PWM) support
- 32.2 cm x 2.7 cm x 14 cm
- 1.8 kg
- Corsair Link
- 5-year warranty
- Product Type
- 32.2 cm
- 2.7 cm
- 14 cm
- 1.8 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Fans Qty
- 2
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2100 rpm
- Air Flow
- 113 cfm
- Air Pressure
- 3.99 mm
- Noise Level
- 43 dBA
- Mounting Kit
- Included
- Corsair Link
- Limited warranty: - 5 years
