Hydro Series H110i is an all-in-one liquid CPU cooler with a 280mm radiator and dual SP140L PWM fans for cooling that’s far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H110i makes it easy for you to protect your valuable CPU.
For efficient cooling, bigger is better – it’s simple physics. If your PC’s case can fit a 280mm radiator, Hydro Series H110i will give you better performance. It’s Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
- Large 280mm radiator: More cooling capacity for cases which have 280mm radiator mounts.
- Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
- Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
- Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
Includes:
- Corsair Hydro Series H110i Extreme Performance Liquid CPU Cooler
- Mounting kit for all modern CPU sockets
- Two SP140L High Torque 140mm fans
- USB cable for Corsair Link. Integration
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
- Quick Start Guide
Radiator of 280 mm
The secret to fast, efficient cooling is maximizing cooling surface area. The H110i lets you take advantage of your case's full cooling potential. -
Advanced PWM fans
The PWM fans are custom-designed for high static pressure air delivery with minimum turbulence and noise and you can customize the fan speed to find the optimal balance of cooling and noise. -
With the Corsair Link you can customize cooling performance, monitor coolant and CPU temperatures, and change the color of the RGB LED lighting to match your system, or to change color based on temperature readings and other inputs. -
High-performance CPU cooling made simple
The H110i features a closed loop design that comes pre-filled. It includes a modular, tool-free mounting bracket for faster installation, and it features improved cold plate and pump designs for highly tuned efficiency.
- CORSAIR Hydro Series H110i Extreme Performance Liquid CPU Cooler - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Package Content
- Thermal paste
- Compatibility
- LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket, Socket AM4, LGA1200 Socket
- Heatsink Material
- Aluminium with copper base
- Fans Qty
- Dual
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2100 rpm
- Air Flow
- 113 cfm
- Noise Level
- 43 dB
- Pulse-width modulation (PWM) support
- Corsair Link
- 5-year warranty
- Product Type
- Package Content
- Thermal paste
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fans Qty
- 2
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2100 rpm
- Air Flow
- 113 cfm
- Air Pressure
- 3.99 mm
- Noise Level
- 43 dB
- Mounting Kit
- Included
- Corsair Link
- Limited warranty: - 5 years
