Hydro Series H105 provides extreme CPU cooling performance. The 38mm thick 240mm top-mounted high-capacity radiator is paired with high-RPM SP120L fans for the fast heat dissipation you need for highly overclocked CPUs. And, PWM fan speed fan control lets you select the precise level of cooling power you need through your motherboard BIOS.
Installation is easy, with an all-new mounting bracket that provides quick, tool-free assembly. The three included red, grey, and blue accent rings let you match your H105 to your DRAM and motherboard color scheme. And, like all Hydro Series liquid CPU coolers, the H105 is completely self-contained, with no filling or maintenance required.
- Extreme CPU cooling performance - The extra-thick 240mm radiator increases surface area significantly for superior heat dissipation.
- Take advantage of your case's 240mm radiator mount - Use your case to its fullest potential with a massive CPU cooler.
- Protect your hardware and increase your CPU's overclocking potential - Keep your CPU frosty at stock speeds or eek out that extra hundred megahertz of clock speed
- Dual SP120L fans with PWM control for customized cooling performance - SP120L high performance, high static pressure fans are optimized specifically for radiator usage.
- All-new mounting bracket design for easy installation - Thumbscrews and snap-in head mount ring design for quick and easy installation on AMD and Intel processors.
- Includes three colour accent rings to match your H105 to your motherboard - Default metallic grey, and added red and blue colored rings to match your Corsair Air Series fans or other motherboard, memory, or GPU colour themes in your case.
- Radiator Dimensions: 270mm x 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: 800 - 2700 +/- 10% RPM (PWM)
- Air Flow: 73 CFM
- Static Pressure: 3.9 mm-H2O
- Noise Level: 37.7 dB(A)
CPU Compatibility
- Intel LGA 115x
- Intel LGA 1366
- Intel LGA 2011
- AMD AM2
- AMD AM3
- AMD FM1
- AMD FM2
Box Contents
- Corsair Hydro Series H105 High Performance Liquid CPU Cooler
- Mounting kit for all modern CPU sockets
- Two SP120L High Performance 120mm PWM Fans
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
- Quick Start Guide
Many newer PC cases providing mounting points for 240mm (dual 120mm) radiators. The greater radiator volume allows for much quicker cooling than traditional single radiators. -
The SP120L fans are custom-engineered by Corsair to deliver higher static pressure with less turbulence and noise. Since they're compatible with PWM fan headers, you can select the exact amount of cooling power you need. -
The mounting bracket is compatible with multiple sockets, and you don't need a screwdriver to securely install it. -
Includes three color accent rings to match your H105 to your motherboard
Dress up the pump assembly in red, gray or blue to match or contrast your system's color scheme.
- CORSAIR Hydro Series H105 240mm Extreme Performance Liquid CPU Cooler - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Package Content
- Y-Split cable, 3 replaceable colour rings
- Compatibility
- LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Copper
- Fans Qty
- Dual
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 800-2700 rpm
- Air Flow
- 73 cfm
- Noise Level
- 37.7 dBA
- Pulse-width modulation (PWM) support
- 27.25 cm x 3.8 cm x 12 cm
- 1.3 kg
- 5 years warranty
- Product Type
- Package Content
- 27.25 cm
- 3.8 cm
- 12 cm
- 1.3 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Fans Qty
- 2
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 800-2700 rpm
- Air Flow
- 73 cfm
- Air Pressure
- 3.9 mm
- Noise Level
- 37.7 dBA
- Mounting Kit
- Included
- Limited warranty - 5 years
