Corsair HX1200i High Performance Series 1200Wt 80 PLUS Platinum PSU
Quicklinx: B8JDWS00 Mfr#: CP-9020070-UK
Power Rating: 1200Watt
Hurry, only 3 left in stock!
£217.72 ex VAT
£261.26 inc VAT
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
  • Quiet, efficient operation
    80 PLUS Platinum efficiency and Zero RPM Fan Mode mean that at low to medium loads, the fan doesn't spin at all. And when you do push the HXi hard, the thermally controlled fan spins only as fast as it needs to. But that's not all. It's quieter than most PSUs when the fan's not spinning, too. The HXi is built with capacitors and other internal components specially selected to reduce coil whine and other electronic noise.
  • Corsair link digital for advanced monitoring and control
    Connect the included cable to a motherboard USB header and download the free Corsair Link Dashboard application for Windows and you can monitor performance and efficiency, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
  • Easy installation
    The fully modular, low-profile cable set allows for quick and easy installation and great-looking builds. The fan self-test switch lets you quickly confirm operation before you even attach cables to your motherboard.
CORSAIR HXi Series HX1200i - power supply - 1200 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
3.592 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 20 cm x 8.6 cm
10 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output Current
+3.3V - 30 A , +5V - 30 A , +12V - 100 A , -12V - 0.8 A , +5VSB - 3.5 A
Efficiency
92%
Modular Cable Management
80 PLUS Platinum
Power cable kit
Cooling System
140 mm fan
Corsair Link, fan speed monitoring, over current protection, over voltage protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fluid dynamic bearing cooling fan, fully modular
CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM
Limited warranty - 10 years
50 °C
15 cm
20 cm
8.6 cm
3.592 kg
Brand: Corsair
Price Range Ex VAT: 150 - 300
