Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
- CORSAIR Air Series LED HD120 RGB High Performance - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans
- White, blue, yellow, red, green, orange, violet
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 800-1725 rpm
- Air Flow
- 54.4 cfm
- Noise Level
- 18 - 30 dBA
- Power Connector
- 4-pin fan connector
- Pulse-width modulation (PWM) support, RGB LED x12
- 2-year warranty
- Product Type
- Case fan
- Package Content
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 800-1725 rpm
- Air Flow
- 54.4 cfm
- Air Pressure
- 2.25 mm
- Noise Level
- 18 - 30 dBA
- Power Connector
- Operation Voltage
- 7 - 13.2 V
- Mounting Kit
- Included
- Limited warranty: - 2 years
