Corsair H75 Hydro Series High Performance Liquid CPU Cooler
Quicklinx: 95JFWS00 Mfr#: CW-9060015-WW
Hydro Series H75 provides effective and efficient liquid CPU cooling in a compact size. The 120 mm radiator has a thickness of only 25 mm and is paired with standard diameter, kink-resistant tubing for compatibility with smaller cases and tighter spaces. The dual SP120L 120 mm fans support PWM motherboard fan headers, so your motherboard can automatically control fan speeds based on CPU temperature. The tool-free mounting system has broad Intel and AMD socket compatibility. A copper microfin cold plate and high-quality ceramic bearing pump help provide reliable, low-noise heat transfer away from your CPU. And, like all Hydro Series liquid CPU coolers, Hydro Series H75 is completely self-contained and never needs filling or maintenance.
  • 25mm thick radiator core (29mm including housing) for enhanced compatibility with small cases.
  • Copper microfin coldplate with high quality, quiet ceramic bearing pump.
  • Easy to use tool-free black nickel finish mounting brackets for modern CPUs.
  • Dual SP120L PWM fans for great performance and adjustable noise levels.
  • Radiator Dimensions: 120mm x 152mm x 29mm
  • Fan Dimensions: 120mm x 25mm (2)
  • Fan Speed: 2000 RPM (+/- 10%)
  • Air Flow: 54 CFM
  • Static Pressure: 2.8 mm-H2O
  • Noise Level: 31.4 dB(A)
CPU Compatibility
  • Intel LGA 1150
  • Intel LGA 1155
  • Intel LGA 1156
  • Intel LGA 1366
  • Intel LGA 2011
  • AMD AM2
  • AMD AM3
  • AMD FM1
  • AMD FM2
Box Contents
  • Corsair Hydro Series H75 Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP120L PWM high performance fans
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
  • Copper microfin cold plate
    The cold plate draws heat from your CPU into the circulating liquid. Copper has outstanding thermal conductivity, and the microfin design provides fast and efficient heat transfer.
  • Dual high-torque 120 mm PWM fans
    Dual fans mount on opposite sides of the radiator for high-speed push-pull airflow. You can connect them to the standard PWM fan headers on your motherboard for precise fan speed control, and select the exact level of cooling performance you need.
  • Broad Intel and AMD socket compatibility
    Hydro Series H75 works with virtually all current Intel and AMD based motherboards.
  • High quality ceramic bearing pump
    The reliable pump mechanism is designed for silence.
CORSAIR Hydro Series H75 Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Ceramic bearing
Rotation Speed
2000 rpm
Air Flow
54 cfm
Noise Level
31.4 dBA
Pulse-width modulation (PWM) support, tool free
5-year warranty
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Ceramic bearing
Rotation Speed
2000 rpm
Air Flow
54 cfm
Air Pressure
2.8 mm
Noise Level
31.4 dBA
Mounting Kit
Included
Limited warranty: - 5 years
Resources
The following resources are available for the Corsair H75 Hydro Series High Performance Liquid CPU Cooler
