The stunning Graphite Series 780T Full-Tower PC case can satisfy the most hardcore gamer or overclocker with ample room for nine drives and nearly a dozen large cooling fans. Into water cooling? You'll appreciate the generous space for dual 360mm radiators. And, you'll get everything done faster: the 780T offers easy maintenance shortcuts like tool-free removal of side panels, hard drives, and graphics cards. A three-speed fan control button and generous options for peripheral connections make the front-panel a true time saver.
Rounded corners and a sleek, cohesive design
A nicely built high performance PC can be a thing of beauty, and this is truer than ever with the artfully crafted exterior. -
Latched side panels for easy access
No tools or twisting are necessary to get at your components for maintenance and upgrades. You'll get in, get out, and get on with your work or play. -
Dual radiator support
Does your next dream build demand state of the art cooling? The 780T has you covered. Of course, if your heat transfer needs are a little more down-to-earth, 120mm and 240mm cooling goes in just as easily. -
Dual 140mm intake fans and a 140mm exhaust fan
The 780T gives you ample airflow right out of the package. Large diameter front intake fans deliver plenty of cool air to your high performance components. -
Front-panel three-mode fan controller and four USB ports
Power is nothing without control. You can be the judge of the optimal noise and cooling ratio. The three-step LED gauge tells you exactly where you're at: one bar for surfing the web, and three when you're pushing your GPUs hard. The front panel also has two USB 3.0 and two USB 2.0 ports, so device management is easy. -
Smart storage configuration
Modular hard drive cages and space-saving side-mounted SSD bays make the most of interior volume. You can remove the cages you don't need, and your solid-state storage tucks out of sight and out of the airflow path.
- CORSAIR Graphite Series 780T - tower - XL-ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- White
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone , 2 x USB 2.0
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
- System Cabinet Features
- Screwless PCI card retainers, screwless drive bays, fan speed controller with gauge, cable management holes, modular HDD brackets, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear, screwless side panels, supports 280 mm radiator in top, supports 280 mm radiator in front panel, supports 360 mm radiator in top, supports 140 mm radiator in rear, supports 360 mm radiator in front panel, supports 240 mm radiator in bottom
- Power Device
- No power supply (ATX)
- 33.2 cm x 68.9 cm x 67 cm
- 11.3 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- XL-ATX
- Internal Bays Qty
- 9
- Front Accessible Bays Qty
- 2
- Product Material
- Steel, acrylic
- White
- Cooling System
- Front: 140 mm fan x 2 / intake , Rear: 140 mm fan x 1 / exhaust , Top: fan mount x 1 / 2 x 140 mm fan or 3 x 120 mm fan supported , Bottom: fan mount x 1 / 2 x 120 mm fan supported
- CPU Cooler Max Height
- 200 mm
- Video Card Max Length
- 355 mm
- Power Supply Max Length
- 260 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 9
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 2 x USB 2.0
- Power Device
- No power supply
- Specification Compliance
- ATX
- 33.2 cm
- 68.9 cm
- 67 cm
- 11.3 kg
- Limited warranty - 2 years
