Your basket is empty
Corsair Gaming VOID Wireless RGB Dolby 7.1 Gaming Headset - White
Quicklinx: BY75WS00 Mfr#: CA-9011145-EU
Enter the VOID - the innovative and exciting new family of advanced gaming headsets from Corsair. Whether you choose wireless, USB, or stereo powered audio gear, you will always be one step ahead of your enemies with fast forward design, spectacular fidelity, and innovative new features like InfoMic and CUE Control, enabling you to command and control your gaming soundscape without hitting pause.
Legendary audio, zero hassle:
2.4GHz wireless freedom up to 40ft + 16 hours of uninterrupted gaming.
Epic immersion and true multi-channel audio:
Genuine Dolby 7.1 surround delivers lethally accurate positional audio.
RGB lighting:
Sync with other Corsair RGB devices, or light your own path.
CUE Control:
Instantly re-spec your gaming audio—EQ, Dolby and volume—with a single digital control.
InfoMic:
Everything you need to know about your audio status, instantly.
Microfiber/memory foam earpads:
Play in comfort for hours. And hours.
Take command: The advanced unidirectional noise-cancelling microphone makes you loud and clear
Corsair Gaming VOID Wireless RGB Gaming Headset - White
Headset Wireless
Recommended Use
Gaming
Europe
2 years warranty
Headset
Recommended Use
PC Gaming
Wireless
Headphones
Frequency Response
20Hz - 20 kHz
Impedance
32 Ohms @ 1 kHz
Drivers
50mm
Connector
Wireless USB Receiver
Microphone
Unidirectional noise cancelling
Headphones
Impedance
2.2k Ohms
Frequency Response
100Hz – 10kHz
Sensitivity
-37 dB (± 3 dB)
Wireless
Range
Up to 40 feet (12m)
Battery life
Up to 16 hours
Packaging
Package Dimension
230mm x 109mm x 243mm / 9" x 9.6" x 4.3" inches
Shipping Weight
910g
Unboxed Weight
450g
Manufactuer Warranty
Warranty
2 years
