Enter the VOID - the innovative and exciting new family of advanced gaming headsets from Corsair.
Whether you choose wireless, USB, or stereo powered audio gear, you will always be one step ahead of your enemies.
With fast forward design and spectacular fidelity, Corsair VOID gaming headsets enable you to command and control your gaming soundscape without hitting pause.
RGB Lighting under your command with CUE software
Express yourself with 16.8 million color options to match your gear and your individual style. LEDs in each ear cup have fully adjustable power, pattern and color to provide anything from subtle and restrained, to eye-grabbing intensity. -
Epic immersion and true multi-channel audio
Efficient 50mm neodymium drivers create staggering bass, scintillating highs, and towering dynamic range, and genuine Dolby 7.1 surround delivers lethally accurate positional audio. -
Noise canceling microphone
If you're a team player, you need crystal clear voice communication. The noise-canceling microphone puts your voice in the spotlight - and nothing else.
- CORSAIR Gaming VOID RGB Dolby 7.1 - headset
- Product Type
- Headset - wired - USB
- Recommended Use
- Computer
- Additional Functions
- Adjustable RGB lighting
- Localisation
- Europe
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Microphone on/mute
- 2-year warranty
- Product Type
- White
- Earpad Material
- Memory foam, microfibre
- Recommended Use
- Computer
- Localisation
- Europe
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 20 - 20000 Hz
- Sensitivity
- 107 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Mono
- Sensitivity
- -37 dB
- Impedance
- 2.2 kOhm
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
Cable
- Cable Length
- 1.8 m
- Limited warranty - 2 years
