Product
Corsair Gaming VOID USB RGB Gaming Headset - White
Quicklinx: BT6ZWS00 Mfr#: CA-9011139-EU
Enter the VOID - the innovative and exciting new family of advanced gaming headsets from Corsair.
Whether you choose wireless, USB, or stereo powered audio gear, you will always be one step ahead of your enemies.
With fast forward design and spectacular fidelity, Corsair VOID gaming headsets enable you to command and control your gaming soundscape without hitting pause.
  • RGB Lighting under your command with CUE software
    Express yourself with 16.8 million color options to match your gear and your individual style. LEDs in each ear cup have fully adjustable power, pattern and color to provide anything from subtle and restrained, to eye-grabbing intensity.
  • Epic immersion and true multi-channel audio
    Efficient 50mm neodymium drivers create staggering bass, scintillating highs, and towering dynamic range, and genuine Dolby 7.1 surround delivers lethally accurate positional audio.
  • Noise canceling microphone
    If you're a team player, you need crystal clear voice communication. The noise-canceling microphone puts your voice in the spotlight - and nothing else.
CORSAIR Gaming VOID RGB Dolby 7.1 - headset
Headset - wired - USB
Recommended Use
Computer
Additional Functions
Adjustable RGB lighting
Europe
White
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Microphone on/mute
2 years warranty
Headset - USB
White
Earpad Material
Memory foam, microfibre
Recommended Use
Computer
Europe
Headphones
Circumaural
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
20 - 20000 Hz
Sensitivity
107 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Mono
Sensitivity
-37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
Controls
Microphone on/mute
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.8 m
