Corsair Gaming STRAFE RGB Cherry MX SILENT Gaming Keyboard
Quicklinx: BV60WS00 Mfr#: CH-9000121-UK
Strafe RGB MX Silent delivers ultra-quiet mechanical key switch performance and dynamic multicolor lighting control. It's up to 30% quieter than other mechanical gaming keyboards without sacrificing the speed, feel and responsiveness you need to win, and with virtually unlimited backlighting customization it looks as great as it plays.
  • Multi-color dynamic RGB backlighting
    Brilliant RGB LED backlighting immerses you in the game with virtually unlimited adjustability.
  • USB pass-through port
    It's ready for your mouse, phone, or wireless headset adapter, and strategically positioned for uninterrupted game play by keeping the cable out of the line of fire.
  • FPS and moba keycap sets
    Personalize your Strafe RGB for your game of choice. The textured, contoured keycaps enable enhanced grip and feel.
  • Detachable soft-touch wrist rest
    It's textured to provide just the right amount of grip to keep your hands in place and provide long-lasting comfort.
  • Gaming grade circuitry
    100% anti-ghosting with 104 key rollover on USB ensures that every keypress registers, no matter how fast you play.
  • Easy-access multimedia controls
    Make on-the-fly audio adjustments without interrupting your game. And when you're not competing, they provide an easy way to play, pause, and skip audio tracks.
  • CUE it up
    CUE Link harnesses the power of CUE to connect your Corsair RGB keyboard, mouse, and headset to work in harmony for the ultimate lighting experience.
  • Fully programmable
    Reassign any key, or set up the most extreme macros for effortless gaming control.
CORSAIR Gaming STRAFE RGB Mechanical - keyboard - UK Input Device
Keyboard
Backlit
USB
Wired
Localization and Layout
Keys Qty
104
Hot Keys Function
Multimedia, programmable, Windows key lock
Numeric Keypad
Gaming
Key Switch Type
CHERRY MX Silent
44.8 cm x 17 cm x 4 cm
1.352 kg
Keyboard
Backlit
USB
Keys Qty
104
Hot Keys Function
Keyboard Technology
Mechanical
Key Switch Type
CHERRY MX Silent
Gaming
Palm Rest
Numeric keypad
44.8 cm
17 cm
4 cm
1.352 kg
USB 2.0
Keycap puller, FPS and MOBO keycap sets
Microsoft Windows 7 / 8 / 10
