After 20 years of pushing the limits of innovation, Corsair Gaming takes the power of Cherry MX German engineering one step further. Cherry MX gaming keys feature the world's leading mechanical key switch technology. Gold-Crosspoint contacts, gold-plated contact closure, and pressure resistant metal alloy springs, give every gamer the competitive advantage. If you're playing MMOs and MOBAs, it's often less about getting your shots in, and more about moving out of ?re. Cherry MX Brown switches give you light tactile feedback, so you know exactly when the keypress is registering. Brilliant RED backlighting enhances the experience with virtually unlimited lighting adjustability. Choose from six unique presets or craft your own.
Cherry MX key switches
Used by the pros and built in Germany, Cherry MX gaming key switches feature the amazing mechanical key switch technology. Gold-crosspoint contacts, gold-plated contact closures, and pressure-resistant metal alloy springs give every gamer a competitive advantage. -
Dynamic backlighting
Brilliant RED backlighting enhances the experience with virtually unlimited lighting adjustability. Choose from six unique presets or craft your own. -
Endless programmability
The Corsair Utility Engine (CUE) unlocks amazing keyboard programmability. Reassign any key or set up the most extreme macros for outrageous gaming control. -
Get connected
Positioned for uninterrupted game play, the built in USB pass-through provides easy connection for your mouse, USB drive, or wireless headset adapter. -
Comfort and control
Textured and contoured keycaps allow for maximum grip and enhanced feel. Personalize your experience by selecting between FPS and MOBA kits. -
Gaming grade circuitry
100% anti-ghosting with 104 key rollover on USB ensure no matter how fast your play, all your keys register.
- CORSAIR Gaming STRAFE Mechanical - keyboard - UK
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 104
- Hot Keys Function
- Multimedia, programmable, Windows key lock, Fn key lock
- Numeric Keypad
- USB hub
- Gaming
- Key Switch Type
- CHERRY MX Blue
- 44.8 cm x 17 cm x 4 cm
- 1.352 kg
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
Input Device
- Keys Qty
- 104
- Hot Keys Function
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Blue
- Gaming
- Palm Rest
- USB hub, numeric keypad
- 44.8 cm
- 17 cm
- 4 cm
- 1.352 kg
- USB
- Included Accessories
- Keycap puller, FPS and MOBO keycap sets
- OS Required
- Microsoft Windows 7 / 8 / 10
- Limited warranty - 2 years
