Corsair Gaming SCIMITAR RGB Gaming Mouse - 12000 DPI
Quicklinx: BN3MWS00 Mfr#: CH-9000091-EU
THE WORLD’S BEST MOBA AND MMO GAMING MOUSE.
The Scimitar RGB gaming mouse revolutionizes game play with its Key Slider control system, 12 mechanical side buttons, and pro-proven 12,000 DPI optical sensor. It’s purpose built to deliver the ultimate MOBA and MMO gaming experience.
Set your thumb free
The exclusive patent pending Key Slider control system provides unmatched customization. 8mm of key slide travel with secure lock puts every button within reach.
Mechanical switches
The 12 mechanical side buttons deliver an unmatched competitive advantage. They’re designed to pro player specifications for ultra-consistent tactile feedback and precise actuation.
12,000 DPI zero-acceleration optical sensor
Harness the power of the pro-proven 12,000 DPI high performance optical sensor for the most pixel-precise gaming experience. It’s CUE tunable for outstanding control during intense gaming.
Four-Zone RGB lighting
Brilliant customizable multicolor backlighting immerses you in the game and provides nearly unlimited lighting adjustability. Each of the four zones can be independently configured.
The power of CUE
Take the full power of your mouse into battle. Don’t just configure your mouse – program it with custom MMO timer countdowns and double macros, RGB lighting, DPI matrices, and more.
Ultra-fast response time
Pushing the limits of the maximum USB transfer rate, the ultrafast 1ms response time ensures that every click counts. Lag-free game play is crucial when everything is on the line.
Supreme comfort
The Scimitar RGB is crafted to fit the contours of your palm for the highest level of comfort, no matter your hand size or grip style.
Package contents
  • Scimitar RGB Optical MOBA/MMO Gaming Mouse
  • Key slider locking tool
  • Warranty card
Compatibility
  • A PC with a USB port
  • Windows 10, Windows 8 or Windows 7
  • An internet connection is required to download the Corsair Utility Engine software
  • Set your thumb free
  • Mechanical switches
    The 12 mechanical side buttons deliver an unmatched competitive advantage. They're designed to pro player specifications for ultra-consistent tactile feedback and precise actuation.
  • 12,000 DPI zero-acceleration optical sensor
    Harness the power of the pro-proven 12,000 DPI high performance optical sensor for the most pixel-precise gaming experience. It's CUE tunable for outstanding control during intense gaming.
  • Four-Zone RGB lighting
  • The power of CUE
    Take the full power of your mouse into battle. Don't just configure your mouse - program it with custom MMO timer countdowns and double macros, RGB lighting, DPI matrices, and more.
  • Ultra-fast response time
  • Supreme comfort
CORSAIR Gaming Scimitar RGB - mouse - USB
Mouse
Wired - USB
7.7 cm x 11.94 cm x 4.88 cm
147 g
Europe
Movement Detection Technology
Optical
Buttons Qty
17
Movement Resolution
12000 dpi
Performance
125/250/500/1000 reports per second, realtime sensitivity switching 100 - 12000 dpi
Programmable buttons, polytetrafluoroethylene (PTFE) feet, built-in flash memory, braided cable, 4-zone illumination, Corsair Utility Engine (CUE), 12 mechanical side buttons
Cable Length
1.8 m
Microsoft Windows 7, Windows 8, Windows 10
Mouse
7.7 cm
11.94 cm
4.88 cm
147 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
17
Movement Resolution
12000 dpi
Performance
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
