Corsair Gaming MM300 Anti-Fray Cloth Gaming Mouse Pad - Small
Quicklinx: C20TWS00 Mfr#: CH-9000105-WW
The Corsair Gaming MM300 is a durable cloth mouse mat for high-DPI gaming mice. Reinforced stitched edges guard against surface peeling, while the textile-weaved surface gives advanced control for lethal in-game accuracy.
  • Advanced control
    The textile-weave surface is designed for pixel-precise targeting and low friction.
  • No fray, no fuss
    The stitched edges guard against surface peeling.
  • Accurate and precise
    MM300 is optimized for both laser and optical gaming mice.
  • Zero slip
    The anti-skid rubber base helps it stay securely in place.
CORSAIR Gaming MM300 Small Edition - mouse pad
Mouse pad
Product Material
Rubber, cloth
25.6 cm x 21 cm
1-year warranty
Mouse pad
Product Material
Rubber, cloth
25.6 cm
21 cm
Thickness
0.3 cm
Non-slip
Limited warranty - 1 year
