The Corsair Gaming MM300 is a durable cloth mouse mat for high-DPI gaming mice. Reinforced stitched edges guard against surface peeling, while the textile-weaved surface gives advanced control for lethal in-game accuracy.
Advanced control
The textile-weave surface is designed for pixel-precise targeting and low friction. -
No fray, no fuss
The stitched edges guard against surface peeling. -
Accurate and precise
MM300 is optimized for both laser and optical gaming mice. -
Zero slip
The anti-skid rubber base helps it stay securely in place.
- CORSAIR Gaming MM300 Small Edition - mouse pad
- Product Type
- Mouse pad
- Product Material
- Rubber, cloth
- 25.6 cm x 21 cm
- 1-year warranty
- Product Type
- Mouse pad
- Product Material
- Rubber, cloth
- 25.6 cm
- 21 cm
- Thickness
- 0.3 cm
- Non-slip
- Limited warranty - 1 year
