The cloth surface of the MM200 delivers excellent glide characteristics that allow you to execute fast swipes and pull off high-precision shots with confidence and consistency. It's optimized for gaming sensors, with a carefully-screened surface material that delivers excellent tracking.
You can't afford to have your mouse surface move in the middle of a firefight, so Corsair added a non-slip base that provides cushion with just the right amount of give. And it's made of natural rubber, so it doesn't have a harsh chemical odor.
- CORSAIR Gaming MM200 Compact Edition - mouse pad
- Product Type
- Mouse pad
- Product Material
- Rubber, cloth
- 26.5 cm x 21 cm
- 1-year warranty
- Product Type
- Mouse pad
- Product Material
- Rubber, cloth
- 26.5 cm
- 21 cm
- Thickness
- 0.2 cm
- Non-slip
- Limited warranty - 1 year
